- Joined
- May 22, 2011
- Messages
- 15,240
- Reaction score
- 1
This is the first unit to be run other than the prototype in my truck, which I have not tested other than fit and seal . This test was done by logan @ centex diesel in texas on his 2015 dually. mods as listed :
No Limit Off Road SCT
No Limit 5" Cold Air Intake
No Limit EGR Delete
No Limit CCV
Flo Pro 4" exhaust
Specs on the Intercooler are right at 30% flow increase in core, and bigger end tanks with better flow angles, and made right here in America.
We haven't done any egt testing as of yet , but the egt drop at cruising speeds seems to be almost 100* with an average of 560* at 70 mph on the highway. We will do a lot more testing with centex and morgan @ Midwest for detailed data numbers with different turbo's and fueling situations.
The horsepower and tq numbers are very impressive , as well he has stated that the increase in throttle response and increase in spool is shockingly awesome.
the unit compared to stock ic -
and the back to back comparison on the dyno -
to say the least I am very pleased with the results on a tune only truck, and if you have seen the factory cooler , you would see they left a lot to be desired.
No Limit EGR Delete
No Limit CCV
Flo Pro 4" exhaust
