one2nine's build thread
one2nine
Altoona, Pa
In the back of my head I keep wondering if the ,
Ar on the turbo never got switched as the stock ar is 1.25. Anyway of checking this?
Josh@DirtyDiesels
PA
Better get her figure before saturday , I wanna see some numbers on that thing LOL
not a damn chance it would make power on axxelerated's dyno. Last weekend travis couldn't spool his 472 on there and I can never light my 72 on that dyno. Would just be a waste of money and a smoke show lol
extreme3807
Bucyrus, OH
My 1.10 would NEVER spool at the line. You could easily sit there for 2 minutes trying to build more than 5 psi
dustinz85
Houtzdale Pa
But ppl love or oraling coal lol:D
Super08Duty
College Station, TX
1.25 wouldn't build boost on the street. Sounds like you have a .98 housing. Low boost fueling is tricky with a big single. You need more fuel to help spool it, but not too much or you'll be dumping smoke. I'd like to see an 80mm with 60 over nozzles. I think that would be a good match.
one2nine
Altoona, Pa
Took a few driving videos to see what you guys think. This was on IDP's custom tune. It actually didn't run too bad on it, but I just feel like the boost is coming on way too late compared to the other single turbo setups. I still have this weird feeling that I may have the wrong AR. For a .9 I would think it would build boost sooner correct? I can't really make out the casting markings on the exhaust housing so once I get some free time I'll probably pull the cover to get a better look and see if I can find what AR is stamped on it.
This was in drive/tow haul 3rd gear. As soon as it hit 4th you can hear the turbo completely fall out of boost and lag.
https://www.youtube.com/watch?v=jL6GQGjyhW0
This is just normal stop light to stop light driving in tow haul as well.
https://www.youtube.com/watch?v=vBcoK-6MxoY
https://www.youtube.com/watch?v=6NDtDdRrTlk
And this just shows the boost coming on holding 3rd gear
https://www.youtube.com/watch?v=uHRC4PAsC-E
What do you guys think?
one2nine
Altoona, Pa
It gets kinda smokey without tow haul at times as tow haul holds out the shifts a little more. I know our setups are two different animals by you're already building 10psi or so of boost around 2200. I'm on a fine line for fueling. If I have the tuners drop the fuel it's doesn't want to drive the turbo but if I have more fuel it turns into a smokey street pig.
Strokin6.4
Yeah I think eric has my trck tuned perfect. Neither of the videos I posted had a hint of smoke. I just ran mine in tow/haul and I don't like it at all! Lol the converter not locking def helps with spool up.
3brorce
Ya, not sure what you expected with a single 80mm. Its not a 6.7C. lol
