Parallel Turbos
Cutting-Edge Diesel
Newkirk, OK
I'm gonna run those s360's and see what's up. I think the 4,000 rpm shifts and nitrous will keep em lit just fine. I'll run the tightest housings I can get my hands on. If they're not big enough I'll run a parallel compound triple setup. How's that for a plan. Lol!
68mm j type turbine wheel and .70 t3 is the smallest I think.
Hotrodtractor
Mingo, Ohio
Why not just get an S36* charger and mount it up front of the engine and use your S482 as the atmosphere and get the spool up you want, with the benefits of compounding and higher more efficient boost pressures?
