Priming a lpop, is done "easily". The directions.that came with mine said to immerse the gerotor in clean engine oil then install. I knew i'd be a while so I used some grease. Mine.still took some cranking to.get to pull oil.
My buddy liked my Melling and decided to.get one.for his e99, with 115k miles, much to my chagrin. He had his.brother help.him pull the frontend and install it. He cant get.his.truck started. I took my cts over and the thing builds 0 icp(duh) and as expected isnt building lube oil.
Hes got the coolant in it already and Im wondering if theres a way to prime.it other.than disassembling the whole.front.end of the truck and pulling the damper again. His damper is.rusty as hell and im sure the holes are rusty. I just see stripped out something in his.future if we have to take it apart.
I buggered my threads up getting the damper.bolt.back in.
Bottom line:Are we gonna have to pull the damper to goop up the gerotor to build oil.pressure?
