Rear diff ID
Bugman
Gypsum, Co
Any particular reason why you use 75W 90 Instead of the recommended 75W 140?
Sent from my iPhone using Tapatalk Pro
It works fine and even when I just ran straight gear lube all I ran was 90 weight
Sent from my SM-A426U using Tapatalk
Bugman
Gypsum, Co
On the Royal Purple, it's a good lube.
On the friction modifier I haven't seen any lube that is rated GL-4 or greater that doesn't
Tiha
Super Moderator
Super Mod
I have always run Mobil 1. it is like 75w-140 I think. It is supposed to have the modifier in it, but I usually get a clunking and end up having to add it anyway.
There is nothing wrong with the 75w-90 or any other weights in that range. If you are changing it at all, that is more than most people ever do.
