Regulated return install
Mesa, AZ
I did mine with the motor out, but realistically, as long as the up pipes aren't rusted to hell, it should take 3-4 hours to do. Are you doing a fuel bowl derete as well? That could add half an hour to an hour.
kwelch08
corpus christi TX
Give yourself a full day because as we all know a lot of times it doesn't go as easy as you think t well or that's how it is for me atleast hahaha. Soak the bolts with something like PB blaster or whatever you prefer over night.
cRaZy8
It took me 2 days install my regulated return that I built from scratch, along with a Juggerpump, Aeromotive FPR, fuel sump, and all new lines front to back.
slc6oh
Utah
Did mine with engine out of the truck. (Driven diesel) and with the turbo & up pipes out of the way i couldn't imagine it taking more than a couple hours. But i agree plan fir a full day if your anything like me and everything that can fight you does ha
Merc82
I built mine with the cab up when I did studs. I had it finished in a day. Also pressure tested it before the cab came down by lighting off the fuel pump. If you build your own, don't skimp on materials. It is worth it to buy a kit, if you add up the price of all the materials. If I would have bought a kit, I probably have ran one from Strictly Diesel. But I like having that custom touch.
Knoxville,tn
Got started on it today, not terribly hard other than reinstalling the driver side banjo. Talk about a real SOB idk how you can do it solo without someone to hold from top side. Hopefully I'll get to wrap it up before the week ends
