Seating injectors
Alfie
Horrible state of CA
Tap Tap... Ting... You know its done when you hear that "ting"...
That's it ? This is how I do it. Tap tap tap, ting, ting , thuck thunckkkkkk!! Bammmmmmm. Bammmmm!! Then I torque the bolt. And final check. Ting. All good.
yzmatt
Helix, Or.
No when I pulled out the injectors none of them looked like that. This all started because I pulled the injectors to replace the injector cups, then when all done I reinstalled the injectors and all good till a few days later it started to smoke raw fuel. I have a post about it called smokey psd. Anyways a couple of guys figured I didn't seat the injectors and burned a lower oring and fuel was leaking in. That was not the case and that started me thinking. The copper orings were all good and the rubber orings were also good. Injectors have 270,000 miles so figured stuck nozzle. So I bought the tool for 35.00 bucks from amazon and thought I would try it. Just wanted your guys opinions.
DEEZUZ
NO PUKESTERS
NWI
E Series are gravy... Straight out of school and at my first(current) gig doing this for a living I was tossed into a sea of E-series 6.0's...
yzmatt
Helix, Or.
Has anybody heard of the top portion of the injector getting f--- up from hitting it? So am I correct the torque of the hold down bolt is what crushes the copper oring
DEEZUZ
NO PUKESTERS
NWI
wait so you re-used the o-rings and coppers on the injectors?
DEEZUZ
NO PUKESTERS
NWI
I dont know of many people who hit them.. when they do they end up like the one i posted, or they just tap the solenoid bolts, not the solenoid itself... but I doubt youll harm it...
yzmatt
Helix, Or.
NNNNOOOOO, not that stupid just new to diesels. Worked on all my gas engines all my life. No i wasted 60 bucks
DEEZUZ
NO PUKESTERS
NWI
How long have u been doing this ? If u don't mind me asking, What school did u go too. ?
4 years... and just a not well known tech school in Connecticut that got bought out by a Lincoln tech... I carried almost nothing over from the course to the Powerstroke world. I have also had quite a few ADS classes in Vegas and Wisconsin
yzmatt
Helix, Or.
Would love to do what you do. A little old to be going and changing a career now. But dang diesels are cool.
DEEZUZ
NO PUKESTERS
NWI
it makes me not want to work on mine. I hate my career... LOL
yzmatt
Helix, Or.
So far you are the only guy who does what I did and I didn't see what I did was wrong. Tapping an injector on the solenoid just seems questionable to me. Alot of people may do it but I don't want to call Full Force and (hey my truck won't run right).
DEEZUZ
NO PUKESTERS
NWI
alright sorry, we got kind of off topic... could you run me past what the issue was and whats the current status of the injectors, in or out? truck running?
yzmatt
Helix, Or.
CTC is the hold down bolt that crushes the copper oring? An old friend told me that the copper oring only seals off the opening til start up and after that carbons seals it. International mechanic back in the day.
DEEZUZ
NO PUKESTERS
NWI
yes, final torque is what seals the copper.. if you remove a perfectly seated injector, meaning perfect torque, perfect cup cleanliness, you shouldnt see any trace of carbon except on the nozzle/copper shoulder
