Shifter issues
T_rider_0013
So I have a 2000 f350 7.3 super duty and my shift lever is pretty sloppy... checked the twos bolts at the bottom by the fire wall.... pulled column apart to check all the bushings and bolts under there..... all looked fine... what would some suggestions be on finding this issue???
Sent from my SAMSUNG-SM-G930A using Tapatalk
pdumont01
CT
Check the bolts that hold the piece that the shift cable attaches to the column on. They are 2 torx bolts that go in from the back side, bet they are loose. If not the cable could be stretched.
Sent from my Nexus 6 using Tapatalk
T_rider_0013
Checked all that all was fine still can't figure it out. Truck is flashing od light as well when shifts into 3rd gear.
