Radioflyer
- Joined
- Jan 8, 2012
- Messages
- 1,889
- Reaction score
- 0
Looking to drop my 08 f250 down to a leveled stance. Going from a cheesy fab tech 6" kit to 2" leveling stance, similar to this carli kit: http://www.carlisuspension.com/ford-super-duty/suspension/lvl-commuter20.html.
From what I can tell, to accomplish utilizing a kit like this, I just need a few items; oe track bar mounting bracket (found on flea bay) and now I'm on the hunt for a oe 08-10 f250 sway bar end links, rear spring block and pitman arm? Does anyone have an idea what the ford part numbers would be? I currently have bilstein 5100's (may be able to re-use) and as far as the lift goes, Everything that is currently on the truck, are just drop brackets (radius arms, taller springs, 4-6" adjustable track bar, etc..). Anyone have any ideas what else I will need? Maybe a cheaper route to go like AA factory coil springs? Just out right buy new coil springs and a adjustable track bar for a 2" setup?
My tires are a 325/60r20 (35.4x12.8x20) I should be able to clear these with a leveling kit correct?
Any insight would be much appreciated.
