Single turbo instal question/review/thoughts
johnp115
Southern MD/Charlotte NC
My stack is obnoxious with the single
I couldnt imagine mine being a stack. Mine is 4in dp, to 5in exhaust to 8in tip dumped about a foot off the ground. Gotta drive it more to see how it sounds, cause this was at 11pm in my neighborhood LOL
they get quite a bit more obnoxious with a non vgt.
Sent from my HTC One using Tapatalk
Yes, its a completely different sound.
Cknox121
Augusta GA
Just wait to first wot run and tell me about that sound lol. You will understand why I'm running delete pipe and stock tail pipe with muffler.
johnp115
Just took it out again, couldn't resist.
Running Gearhead race setup for the stockers. Should get a revised tune by Monday.
Once 4th locked I got on it, and damn it pulled hard as hell! Roads are a little wet and at 50 it broke loose.
Max 43psi and Max egt 1295 but those number will probably change with tunes.
Also it'll probably change with tunes, but normal accel it doesn't go over 3 psi and the egts do climb, kinda like driving with the Vgt unplugged.
Feels like it's hard to get to 10psi but once it does it's lit and gone
Cknox121
Augusta GA
Sound about the same as mine. Hard to get to 10. I find it easier to drive on the hd300 file low boost set on 5. Seems like it stays spooled 1-2 more psi cruising vs gearhead tuning. Smoky mofo though.
Mike@MPD
Pasadena,MD
Ah was gonna see if you wanted a ride in my truck to see how a big single spool
bft blue oval boys
Burlington, NC
Fyi, if you have an interior that isn't black, make sure you keep the back window closed! My headliner is FUBAR-D! Ughh
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
