Has anyone ever taken there marker light apart and put a smoked lenses on them I want one that I can change the bulbs in as need any info or help would be great. Might have to take the dive and buy a smoked set and swap out the lenses
VHT nightshades and the stock lenses. 2 coats on them will be plenty. Let you be able to change the bulbs instead of being LED's where you can't change them and way cheaper than buying another set
I have no more Amber on my truck, that's my reasoning for taking the clear smoked lense off my recons and mounting them on stock housings, then I can use clear led bulbs and change them whenever
There is no way I would ever buy any other recon light setup for anything. Nothing but bad luck. I would never recommend them unless you just want to remove their clear smoked lense from the mirror lights to install on factory housings.
Bought some VHT to do my mirrors and bed markers, you guys scare me haha. I have their cab light lenses installed on the Ford bases, no issues but cheap bulbs, need some shorter 360' LED's
