someone should try it
Dzchey21
wyoming
Oil drain pretty much has to go in the pan... feed not sure there are some.plugs in the side of yhr block that look like oil galley plugs but I'm not certain on that.
I was going to try and mount mine off the center section since my Turbo is so heavy o wanted the bracket ballanced. But taking both housings off works for mock up just gotta be careful not to damage tge wheels. I'm betting john is done before me
Charles
90% of the total weight is the turbine housing....
Man up boys... I stood on the battery with one foot on the cowl and had no issues aligning and mounting the GT47 by hand.
Get.....R....Done...
On Edit:
You can see my mount I did on the 7.3 back in the day. 1/2" plate construction, using the AC mount bracket. Has never given a minute's trouble. No reason why you guys couldn't do the same sort of thing coming from whatever location you have available on your engines.
Nos_GTSR
Rexburg, ID
Ive got a bracket fab-ed up out of thin steel that uses the 2 front manifold bolts and then Ill run a extra support off the 2nd alt holes Im just waiting for a place to open to buy some 1/2 plate and cut it out. My biggest hold up on the intake is finding a boot thats 5.5". Downpipe is going to be fun but very do-able.
Charles
Mine was 6" but equally hard to find. I ended up getting it from some import turbo shop like boost logic or something.
If you're fine with rubber, then your best bet would be big truck parts suppliers. They'll have huge intake boots for all those turbos on big trucks and they'll usually also have them in angles and sharp 90's and all kinds of good stuff like that.
Dzchey21
wyoming
race parts solutions has a 6 inch elbow, im going to have to get mine mounted before i go to much farther. working on mine tonight, keep us post jon
Nos_GTSR
Rexburg, ID
Got some honky setup figured out for the intake for now, never know what youll find at car quest. I got the bracket 90% done.
Nos_GTSR
Rexburg, ID
Dustin this is what I came up. It uses the lower 2nd alt hole closest to the cab and the front 2 header bolts.
Dzchey21
wyoming
Looks good looks to me like your Turbo is going to be a little farther forward then what I had in mins but looks straight forward nice work. Gunna try to mount the Turbo up this weekend?
Dzchey21
wyoming
Any further back and the downpipe would hit stuff.
alot of stuff in that area has already been moved on my truck is probably why i was thinking farther back, but actually i think i can make a bracket very similar to yours and make it work, thanks for the pics.
Dzchey21
wyoming
yeah ill snap some pics tonight or tomorrow, my daughters birthday party today so im not going to get much done.
Nos_GTSR
Rexburg, ID
Getting closer. I think I might have a pretty good thought how to do the wastegate. Just need to get some 2" bends here to see.
Dzchey21
wyoming
looks good so far, looks like i do have a little more room twoards the firewall then what you do, but your making really good progress so far, looks like i got some catching up to do...
Nos_GTSR
Rexburg, ID
Im still trying to figure out where to get oil and where to tap into the pan at. I think Im going to have a oil fill machined like the mdp but angled.
