Stage 2 injectors from rosewood
Baker42
New Mexico
For those of you running a stage 2 injector 160/80, I would like to know what kind of fuel economy can be expected? I tow alot and would like to see more power without costing me more money at the pump. Thanks
Fenker
Boulder creek, ca
I just installed rosewood 160/100% and am towing 1700 miles in 2 weeks, I plan on keepin track of my milage, I'll be running wvo so it will be a little less but I'll let u know.
HairyPalmer
Pasco, Wa
I didn't notice any difference in fuel economy towing or not........ unless I put my foot in it. I get 19.5 mpg unloaded and about 13-14 mpg towing my boat. I will say, I'm pretty sure I will get more out of them once I step up to the T-500 hpop.
Baker42
New Mexico
Also I have a bass tracker 19 foot PT-190 with a 125 merc out back and in my tow/haul mode (80hp) Im only getting 13, and about 16.5 to 17.5 unloaded
baderic03
warren ri
those injectors all the way up to his 200/30 you will see better fuel economy as long as tune is good and your right foot isnt into it. i run 250/200s and im getting like 15mpg around town trying to not be in it all the time
OBSWIZ
Wellington NV
200/30% won't flow what stage 2's will..just a waste of $ IMO..
I have stage 2's and a modded H2e kit..pulling a JK on my big tex weight about 8k+ pulling hard..65-90mph when needed from so cal to home up 395 adv 12.5
Empty town 15..If I can just drive steady 65-70 can hit 18+
Modded H2e IMO best turbo for these in's ..we have a full kit for the OBS's with Bellowed uppipes..
Now..stage 1's will tow just as easy pulling heavy and get better empty MPG set up correctly..really the best option..unless ya have to have 400+ HP, less $$$ for support mods.
Don't care what anyone says you just defuel larger inj's down lots to be able to pull heavy..
Fenker
Boulder creek, ca
Ya 200/30 flow the same amount. I talked to Jim about the choices. He said stage 2 flow better and come on faster, as for 2.5's make constant power throughout. Both make same max power. Sorry baderic but u should have gotten stage 2's
baderic03
warren ri
but a 200/30 doesnt require the use of a bigger hpop
Fenker
Boulder creek, ca
Ya but even with bigger oil ur still loosing........ the 200/30 take alot longer to empty the fuel even with bigger oil.
But it depends on what ur using them for. Stage 2's for performance stage 2.5 for a low budget build.
