Step by step build process.
Eastern Shore Of Maryland
Looking at doing a progressive build. Start with a 362 68 .91 and stock injectors. Then add fuel and reg return. Then 225/100 injectors with fuel pulled until I can add a s471 in a compound setup when time/money allows. I guess my question is whether or not stock injectors will spool the 362 and if enough fuel can be pulled from 225/100 to not be terribly smoky?
Pizza pig
MD
I would use the .83 housing versus the .91 on that charger. Divided pipes? Spool up will be instant a non issue with stock injectors. You can pull enough fuel to keep is smoke free with 225/100s just tell your tuner. I would recommend using a 475 over a 71mm as the low pressure.
Hope that helps.
strokethis_06
Hope that helps.
WHS
Pizza pig
MD
.83 will spool faster, hit up Matt at Cutting Edge he can hook you up.
