stackedstroker
so i went to go grab breakfast this morning, and about halfway there i was going up a hill and went to accelerate a little to not loose speed and the truck started shutturing real bad. i looked behind me and and could see a little blue smoke, i pulled over and it was romping really bad at idle like it was trying to cut off. i turned around and headed back to the house, i checked for codes with my edge and it showed all the normal codes. i popped the hood and i could see blowby coming out from under my ccv box and it poring out of the tube. then i took the oil fill cap off and its rolling out of there pretty good to.
its not really under pressure its just rolling out.
but what i dont get is if i unplug the icp sensor it idles smooth but the injectors sound like there starving for fuel, and my fuel pressure dropped about 6psi
what do yall think? dead cylinder
could it be injector problem?
i dont have AE so if i can get ahold of a compression test tool im gonna try that.
