superdutyfarmer
Put me on the list for hoops please, Would like to see how they come out
may take longer for the 2011s because they will be different if im not mistaken
Driveshaft Loops: All trucks must have at least six inch wide u-joint shields around the rear ujoint
constructed of at least 1/4-inch steel or 3/8 inch aluminum that will safely contain the u-joint
and the end of the rear shaft. All shields must be securely mounted to the vehicle. Any front shaft
u-joint that is visible from the side of the truck must be shielded to contain the u-joint and the end
of the shaft.
The fab skills look excellent - and driveshaft loops are always a good idea - but I couldn't help but notice that these loops don't meet the rules for most pulling organizations - for the pulling customers does he intend to make a setup that fits those rules? I'd love to have a place where I could send people to buy a product.
NADM's rules:
of the shaft.
I am interested in the drive shaft loops. Please put me on the list.
Are the rear 1 piece drive shaft loops and 2 piece drive shaft loops going to be the same incase some of us with a 2 piece convert over to a 1 piece drive shaft?
I understand that they want to contain the u-joint if it fails, but why not make it mandatory that there is a loop 360* around the drive shaft at the T-case/Trans and Carrier Bearing (if applicable) so that the drive shaft could not dig into the track?
Driveshaft Loops:
All trucks must have at least six (6) inch wide u-joint shields around all u-joints on rear
drive shaft constructed of at least ¼ steel or 3/8 aluminum that will safely contain the ujoints and the ends of drive shafts. Any u-joint on the front axle that can be seen from
front or side of truck must be shielded the same as all other u-joints. All shields must be
securely mounted to the vehicle. A new puller may be granted a one time wavier.
| YouTube Video |
Im in for the loops. Pm me when ready. I have a one piece driveshaft.
