Tunneling the Firewall
Dzchey21
wyoming
Mike's truck Eriks Truck, and my truck all had downpipes with no issues. the only thing I did was bend back the inner fender bracket. They had 5 inch downpipes with no issues, I had a 4 inch, it was tight but I knew I could go with 5" if needed
johnp115
Southern MD/Charlotte NC
I got something not right then. I will switch downpipes and see whats going on
What down pipe are you using? One that came with your single turbo kit? I had a single, 4in down pipe, 6.0 manifolds and custom uppipes and everything cleared fine. The angle/position of the single turbo is different than stock compounds so you have to make sure you are using the right dp
Trav-O
TN/KY Line
The one that came with my kit wouldnt even come close to working. I used the 4" one I had with the factory setup and welded in a new flange. i cant trim anymore off the top side unless I change the wastegate setup completely
