VGT Compound Build
Six_Sloww
Southeast MI
Silly hell cat was napping
I didn't exactly cut the tree down myself.
They prepped the street and actually made it worse than any surface I've ever launched on. Apparently it got WAY better as the day went on, I wouldn't know I only got to make 2 passes 3 hours apart.
I guess the crowd went ape **** though. Wish someone had a video trackside.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Black AOD
Ohio
I should have come up last night when I was only an hour a half away. Dammit.
Sent from my VS990 using Tapatalk
Six_Sloww
Southeast MI
Yeah the hellcat staged before I did, lazy bump on my part... almost rolled right through the damn beams lol
Six_Sloww
Southeast MI
https://youtu.be/5XXT764Z9Po
Second run. I wasn't expecting the lights to drop just wanted to be ready, worked out though because I left on low boost and it didn't spin.
You also can get an idea of how fast this setup spools.. I was at 1500 rpm when the lights dropped and probably had close to 15 lbs of boost when I let off the brake.
Six_Sloww
Southeast MI
dsmracing1
Alberta, Canada
Wow that charger combo sure is spot on!
Six_Sloww
Southeast MI
Dude! Hasn't anybody told you that vgt compounds suck?! They don't make any power! [emoji849]
Sick build Cody, I love it!
Yeah... Thanks for the terrible ideas, should've listened to Facebook.
Thanks! Seeing what what speeds you're trapping at with all that weight shows I need to turn it up!
