Wastegate or not.... need help
CT9AIX
MA
I'll keep this short and sweet. Currently have a EGR catalyst pipe on truck that is cracked/leaking and needs to come off one way or another and also have Rudy's HD up pipes on truck which are holding up so far. Do I just move EGR block off plate up top, relocated EBP sensor and call it a day, or pull cab and add wastegate up top? Mods listed below and I'm seeing approx 75-79 absolute exhaust pressure using DD under WOT.
Side note, I'm 100% happy with power level and have no future plans off adding bigger turbos/more power/more fuel. Thanks in advance.
- Elite valve springs/Push Rods
- Single stock HPFP/ Stock injectors with no plans of adding nozzles
- Rudys HD up pipes
- Elite Tow Power Plus turbos
CT9AIX
MA
thats what i was leaning towards but i was thinking the BP was a little high? am i just being overly worried?
B585Ford
WV
Ebp isn't too crazy, but you have the upgraded valvetrain to handle it so I wouldn't worry too much.
:whs: With your valvetrain upgrades, reasonable EBPs, and no future plans for more, I wouldn't worry about a gate.
CT9AIX
MA
Cool. I've been debating on either set up all week and couldn't make up my mind. One of those cases where just needed some outside opinions. Thanks for the input
