I'll keep this short and sweet. Currently have a EGR catalyst pipe on truck that is cracked/leaking and needs to come off one way or another and also have Rudy's HD up pipes on truck which are holding up so far. Do I just move EGR block off plate up top, relocated EBP sensor and call it a day, or pull cab and add wastegate up top? Mods listed below and I'm seeing approx 75-79 absolute exhaust pressure using DD under WOT.
Side note, I'm 100% happy with power level and have no future plans off adding bigger turbos/more power/more fuel. Thanks in advance.
- Elite valve springs/Push Rods
- Single stock HPFP/ Stock injectors with no plans of adding nozzles
- Rudys HD up pipes
- Elite Tow Power Plus turbos
- Rudys HD up pipes
