Ipkyss
- Joined
- Jul 16, 2011
- Messages
- 1,032
- Reaction score
- 0
Well its been a year since I took mine off. Maybe with that many more out there. Someone might have an idea what my previous issue was.
I am going to be adding some more power shortly and will need the gate back on to control backpressure
Issue was. Get the gate set up. Max backpressure where I wanted it. No problem. Roll into the throttle, no problem. Boosted launch, no problem. Everything was working perfect.
Driving at lets say 40mph. Hit the throttle to pass someone, Truck would only build around 25-30psi boost, smoke like a frieght train, and not get out of its own way. Same thing if you were doing a burnout/ drift. Lift off the throttle for a second and it would fall on its face when you got back on it.
The best idea I could come up with was the backpressure was blowing the gate open before the boost came up to hold it closed.
This was pre 71mm low pressure.
Originally had the gate full boost to the bottom, regulated to the top.
Then full boost to the top, regulated to the bottom
Then full boost to the top, vent to the bottom just to try an keep the damn thing closed.
Same issue every time.
Checked the springs, I believe they were 27lb? or whatever the strongest ones were, I forget now. Checked the diaphragm. Verifield the gate opened and closed right. And it is a percision gate straight from Elite.
Never figured out the issue.
