Super08Duty
The time has come for more power. This go around me and Morgan (Younger1993) will be pulling my cab ourselves and doing all the work to the truck. The truck already has the following mods:
MPD Single kit minus turbo
Elite Built 5R
ARP Studs
EGR Delete
Full Exhaust
6.0 Manifolds
Stock fuel system
CFM intake
BOV
Bullseye 45mm wastegate
598hp 1070trq 12.64 1/4 mile
Mods going on the truck will be:
GOGO Intake manifold
100% MPD 6 Hole nozzles
Elite Stage 1 pushrods
Rudys Stage 1 Valve springs
New rocker assembly on cylinder 5
Custom Fass 150 Low pressure system
Custom Fuel bowl and Fuel cooler delete
Fuel Fittings and hoses
Single Pass tranny cooler used for frame mounted fuel cooler
Dual Fuelers
Ported Fuel rails
Most likely a PT7675 dual ball bearing
Custom 5" intake
Cab was lifted last night. Valve covers, Injectors, Valvetrain minus springs, fuel bowl, fuel cooler and some other small stuff are out. I have some pics that ill post when i can and should be posting as progress goes.
Elite Built 5R
ARP Studs
EGR Delete
Full Exhaust
6.0 Manifolds
Stock fuel system
CFM intake
BOV
Dual Fuelers
Ported Fuel rails
Custom 5" intake
