white swallow build
Super08Duty
College Station, TX
The time has come for more power. This go around me and Morgan (Younger1993) will be pulling my cab ourselves and doing all the work to the truck. The truck already has the following mods:
MPD Single kit minus turbo
Elite Built 5R
ARP Studs
EGR Delete
Full Exhaust
6.0 Manifolds
Stock fuel system
CFM intake
BOV
Bullseye 45mm wastegate
598hp 1070trq 12.64 1/4 mile
Mods going on the truck will be:
GOGO Intake manifold
100% MPD 6 Hole nozzles
Elite Stage 1 pushrods
Rudys Stage 1 Valve springs
New rocker assembly on cylinder 5
Custom Fass 150 Low pressure system
Custom Fuel bowl and Fuel cooler delete
Fuel Fittings and hoses
Single Pass tranny cooler used for frame mounted fuel cooler
Dual Fuelers
Ported Fuel rails
Most likely a PT7675 dual ball bearing
Custom 5" intake
Cab was lifted last night. Valve covers, Injectors, Valvetrain minus springs, fuel bowl, fuel cooler and some other small stuff are out. I have some pics that ill post when i can and should be posting as progress goes.
White_monster
The great white north
You were asking how the dual fueler lines go so here you go.
Here's how the lp systems ties in.
Sorry the last pics not perfect.
Well that's all I got for ya for pics. Make sure the "T" junction doesn't touch the hpfp electrical connector or you'll have issue later on due to rubbing and grounding out. Have fun.
Rene G
Whitemonster, are those hp lines custom made or do they come with the kit? Do you know what the pressure rating is on them?
Crack85
Midland, Tx
Looks sweet. Should be drinking gas and hauling ass when ur done.
Sent from my SAMSUNG-SGH-I727 using Tapatalk
