white swallow build
Erikclaw
Central CA
I thought I snapped a drive shaft at first. I was also only going about 10mph when it happened on a dirt road.
Jhaddox
Negley, OH
Same thing happened to mine and it was an intermediate...loud snap then no gears at all...just would rev
MorganY
college station, tx
Did yours throw codes when that happened?
One would think the TCM would say WTF from the shaft sensors if that did happen...
I dont see a stage 5 snapping an intermediate under his conditions. Maybe during a sled pull or something of the sort?
blk350on20s
Ive snapped intermediates, planetary, and inputs and just a quick snap. No noise afterword. No codes. No movement. Id pop that trans out on the ground and check shafts. Only takes an hour.
MorganY
college station, tx
^ only takes a hour to see how much money you just trashed. Lol
Making pwr sucks sometimes
If its the converter, phil will take care of it no doubt.
I just don't see it being a output or int shaft issue. But I'm sure anything can happen. Output shaft isn't snapped for sure. Trans will be pulled regardless, pressure will be checked before it comes out though just to have some idea of what's going on.
Mike@MPD
Pasadena,MD
Yup been there a lot lol. Input intermediate planetary. Tc. I've broken everything possible
powered by this (╯°□°)╯
blk350on20s
Mine were^
Younger. Backup probably will do no good as the converter will probably have to be sent away and taken apart for removal of the busted shaft.
Fast-6.0
Alamosa, CO
There are two different 300M shafts (different manufacturers). I have broken both of the newer shafts 300M.
My breakage was caused by bind up (poor tuning).
Dieselfarmer
Input shafts snap like candy! Yummy, I can weld it for you, thats what i did to my billet one and then did some super secret heat treating, then sold my truck, it worked awesome! Let me know if i can be of any assistance to you.
