Big Bore
unless it's in a compound setup? A stock injectored motor can't make enough boost to even come near needing a wastegate, and for most trucks running a 38R they have either stock injectors, or stage I-II's, which isn't going to make enough boost to matter.
Just wondering if I'm missing something. OBS trucks didn't have a WG, and I know for a fact those turbos will take 32psi all day long every day. Van turbos don't have a WG. I have the WG tightened shut on my 38R with 175/30% injectors and never see over 30 psi.
Now I see Lott running compounds with a 38r using the factory WG.
