the build before the build
which one?
  • single s472
    Votes: 9 50.0%
  • drop in 72 atmo
    Votes: 9 50.0%
  • Total voters
    18
  • Poll closed .
stroker221
indiana
Lol ya you called it. Unless someone at Midwest talks me into the 71 then it'll be the 67. I was about to order a drop in and white_monster talked me out of it. This makes more sense
powerstroked08
Pennsylvania
I would stick with the 67. It will spool good for the street but will work really well as a high pressure charger in a compound setup. Plus the 67 should spool quite a bit faster off of the line once you do your next part of the build.
powerstroked08
Pennsylvania
Yeah instead of it dumping to the down pipe it would go to the low pressure charger with a hot pipe. And the intake would be different. But that's trivial really(the intake I mean).
stroker221
indiana
Where can I get the 90* boot that connects to turbo? Basically what comes with the no limit cai. I'm gonna still use my s&b intake for now and I've seen where someone else has done this but don't know where they got the rubber 90 to attach the turbo and box
stroker221
indiana
Update
stroker221
indiana
Just realized the downpipe in the kit didn't come with the provision for my wastegate. Sooo what should I do? Fabricate the downpipe to use the gate I currently have or not run one at all?
stroker221
indiana
Two freeze plugs blew out. Looks like ill be lowering trans since the one is on the back of the block. Fml.
stroker221
indiana
Anyone know anything about the oil feed line? Supposed to cut original line to tie in with one thats in kit??
