that is a sexy sumbish!! im digging the ccv bungs on both vc's!!![]()
It's ok, I had a slight motor porn chub as well.
Tapatalking from a Wind Turbine
So I spoke to a guy at the aeromotive tent at beans this weekend, obviously talking about fuel systems. I'm currently running a sump to a single filter set up, to a walbro pump, to the front of the head, out the back, to the front of the next head then returned back to the regulator then back to tank.
He says he has been doing r&d with filters before and after the pump..he says more air is generated when the filter is on the suction side of the pump, and substancially less when the filter is ran after the pump.
Also, instead of running in, then out of the heads, that he says to run through the regulator, then a 4 port block and feed a constant 62 psi to each end of the head. Would too much turbulence be cause inside the rail? Like two hoses fighting each other?
Discuss
you want constant pressure at the heads regardless how its ran... the way you explained it is that fuel goes into regulator then to a feed port to the heads. that would cause bad pressure drops and needs a return line to the tank to let air escape.. you basically want a stock fuel bowl with four feed lines going out the bottom and the return line with a regulator going out the top... that way pressure stays above 60psi to all 4 ports and air can bleed back to the tank..
get ahold of dentexpowerstroke on here...
do what dentex did... find his "year of the 7.3" thread. he posted pics of his setup..Yea, that's why I explained it that way. He said to run it through the regulator first? I asked him why first. I understood that the pump keeps the constant 60psi going TO the heads the the regulator KEPT yhe 60 psi in the heads. He said no. Unless he or I had too many and explained it wrong. But yea, I agree with you. A1000 supplying to engine compartment, filter housing mounted somewhere, then a 4 port block, supply heads, then how to get air out of heads?
The air can go back through the regulator via the return port. The way I have my fuel block made the return port is on the top of the block and will return any trapped air. The way I see it when you run the fuel through the heads constantly it just heats it up more. My fuel block has a feed port in the front side, 4 ports on the sides feeding the heads and the return out the top.Yea, that's why I explained it that way. He said to run it through the regulator first? I asked him why first. I understood that the pump keeps the constant 60psi going TO the heads the the regulator KEPT yhe 60 psi in the heads. He said no. Unless he or I had too many and explained it wrong. But yea, I agree with you. A1000 supplying to engine compartment, filter housing mounted somewhere, then a 4 port block, supply heads, then how to get air out of heads?
Not running a pre filter before the pump would scare me a little. Not having any filtration at all seems like a trashed pump waiting to happen imo
Has anyone played with regulating the line pressure pre injector?
If the block only had 4 ports going to the head and one feed port and regulating it elsewhere then no it won't get the air out. But when setup like my system it with a return port on the block that goes to the regulator then the entrained air can go back down the returnI did forget to mention the small inline filter with ball valve, would go before pump. That's what I was trying to figure out...how putting 4 supplies into the head, with only 4 ports on the head, would let the air escape. I'll just stick with a Y distribution block, to the back of the heads, then front of the heads to the regulator
Doesn't factory run a water seperator on the pressure side? And if I'm not mistaken there is no filter before the pump and I havnt heard of the stock pumps going out from dirt or water.
yesDoesn't a fuel\water separator have to be on the suction side of the system to function properly?
