New setup (going single turbo)
Somd_6.4
This is my first post on here and with a new build in the process I figured I'd post up a thread. the truck is a 08 ccsb, the setup on the truck last year was a 72atmo/stock vgt, 60hp nozzles, dual pumps, suncoast built trans, caltracs, rudys fuel bowl ******, airdog, with ******** tuning. Fastest pass with that setup was a 12.01 at 111, but the truck pushed coolant almost every pass.
So that brings us to this year, the truck came apart a couple weeks ago and found that I had a couple bent valves along with a blown gasket. So the plan for the new setup will consist of a 472 with 60% over nozzles, along with pushrods and valve springs. I would like to see this setup get me to 11.50s or so on fuel before it gets sprayed.
I will also post some pics up of the truck and old setup, as well as the new one as I get them.
Somd_6.4
Black AOD
Ohio
I dig that Green powder coat. Even the dual fueler pulley and Fuel distribution block are color matched. Badass! Good Luck Dude! And Nice Build!
Somd_6.4
Hopefully have a few new pics to post up in the next couple of days, as well as my turbo showing up. If all works out hopefully be making smoke again by next week.
Somd_6.4
Just a little update truck should be done next week. Ended up sending the 60s back for 100s so hopefully have everything buttoned up end of next week.
