40-45 mph hop/vibration issue
Layson
Question for you hoppers.... without going through all the responses in this thread.
How many guys that have a dually or Dana 80 or a Dana 110 have the hop....
Hoppers LOL
Layson
Can I see some pictures of peoples rear axles of where it connects to the driveline that have the hop?
gnxtc2
Bergen County, NJ USA
Did you guys make a brace to tie the frame by the radius arm mounts together? Also, do you sell those shocks with the special valving?
On my OBS, there is a crossmember by the front fuel tank and the trans crossmember. Both crossmembers have brackets coming off them going to the frame flanges.
Billy T.
gnxtc2@aol.com
Here are some pics of the crossmembers on my OBS and trans crossmember.
If front of the rear shocks
Right after the cab
Trans crossmember
Billy T.
gnxtc2@aol.com
the 2017 250 and 350 have fully boxed frames. i bet no more hop...
Arconalloy
Warner Robins, GA
Yea probably right ^^^, I want to get mine situated but I just don't see all that crazy bracing like that completey necessary but I've been wrong before
Layson
Yeah I don't think the bracing will get rid of the hop. That may improve slightly the handling but that's it... the frames are plenty strong in these trucks.
I looked at a cclb truck the other day that didn't have the hop and it had a different driveline then normal....
i can watch my entire body line in my mirror and when the hop occurs, i can see it flex between the bed and box.
Single piece driveshaft?
I don't get why people want one piece drive lines. I'll still take my perfectly dialed 2 piece any day..
I much prefer my one piece shaft over that two Ive maintained for 16 years. After working on it once it becomes obvious why a single shaft is desired.
I made an adjustable bracket for my carrier bearing but its still not as smooth as a single. No spot @47 where it starts to vibrate, etc
Breaking Habits
Mapleton, Illinois
As long as the angles match, and the carrier is adjusted I've never had a 2 piece vibrate
But on a high horsepower situation it takes so much more to make a 1 piece take what the two piece can. These guys have to make these huge driveshafts when a stock F450 2 piece takes it all day every day @ 1000..
