Breaking Habits
Exactly my thoughts!
Hence why I say factory springs and traction blocks over aftermarket springs!
Doesn't the F450 have a different frame?
Question for you hoppers.... without going through all the responses in this thread.
How many guys that have a dually or Dana 80 or a Dana 110 have the hop....
Did you guys make a brace to tie the frame by the radius arm mounts together? Also, do you sell those shocks with the special valving?
On my OBS, there is a crossmember by the front fuel tank and the trans crossmember. Both crossmembers have brackets coming off them going to the frame flanges.
Billy T.
gnxtc2@aol.com
i can watch my entire body line in my mirror and when the hop occurs, i can see it flex between the bed and box.Yeah I don't think the bracing will get rid of the hop. That may improve slightly the handling but that's it... the frames are plenty strong in these trucks.
I looked at a cclb truck the other day that didn't have the hop and it had a different driveline then normal....
Nope its still a two piece.
I don't get why people want one piece drive lines. I'll still take my perfectly dialed 2 piece any day..
I much prefer my one piece shaft over that two Ive maintained for 16 years. After working on it once it becomes obvious why a single shaft is desired.
I made an adjustable bracket for my carrier bearing but its still not as smooth as a single. No spot @47 where it starts to vibrate, etc
