American Force 22x11 Wheels
KingRanch6.7
Cool man i appreciate it I've got the same truck except mine is tuxedo black and I like the burnout design
Swampfox
TN
I did no trimming. I did pull the fender liners back just to make sure there was zero rub.
Taslim_6.7
Hey can anyone give me advice ? T have a 2015 F350 long bed. I don't want to go to lift crazy, and I was wondering if anyone knows how a 22x11 with a 0 offset would look. Running a nitro terra grappler. This is what they recomend to me since I don't wan to go crazy with the lift .
i had no idea that the 11 wides were so inset, wonder why the hell they did that
Not from AF mouth but the 22x11 is an oddball size that was intended for guys running stockish sized rubber but a hair wider without the wheel hanging out the fender.
Crap wheels, but xd was the only 11 wide that was decently offset. Not a reco for xd just pointing out the goofy offset 22x11 was a shot in the dark and the aftermarket clung to it for some reason.
I would stick to the universal offsets as jared mentioned. Whether you want a 17 or a 24. Stick to 10s and 12 wides with sensical negative offsets. On a 11+ obviously a 10 wide is best.
Swampfox
TN
For some reason the pic is gone again above. I liked my 22x11's with 35" Toyo M/T's. Had a 2.5" carli leveling kit with OUO ALA's and rear 4" blocks.
DarcyB
Airdrie, Alberta, Canada
So what I get from this is you can fit the 22x11 with 35x12.5 or 325/50 on a 2.5" level with no rubbing without trimming....or go with 22x10 with same tires on a 4" lift minimum without rubbing and trimming. And that's just because of wheel offset.
Sent from my SGH-I337M using Tapatalk
04cr450
harford county, maryland
You will still have to do a touch or trimming.my advice would be get front bumper spacerS for kb fabworks... no rubbing what so ever - even with my 22x12 325/50's
DarcyB
That trimming is just on the bumper brackets then? Or the fender liner as well? ...I replaced my stock bumper with a herd bumper so I don't think the bracket spacers will be an issue/need.
SVTDiesel
Massachusetts
I run a 22x11 XD wheel with a 325/50/22 tire on a stock height 2016 F350 with zero rubbing. That's no lift, no leveling kit. And the tires stick out about an inch.
