im pretty sure that track times prove that 2011-2014s are only good to a little over 450ish hp with stock fuel and turbo. then with a 15 pump they are near 480ish due to being turbo limited.. but that info might be a couple years old from around the time i started messing with mine. last track times i have put it at 450 hp. might be stronger now with the new tunes but it drops rail so i cant hold it for very long to verify.
I would imagine that the ability to hold rail pressure can/will change the HP output of a 2011.
We did a lot of research on the subject before starting our testing and our numbers fall right in line with what we were told to expect from guys much more experienced in the 6.7 game.
When asking whether we should test the 2015 pump with the 2011 turbo, most said it was a total waste because the gains would be minimal if any at all (5-15hp max). The stock 2011 turbo is pretty maxed out on a healthy 2011 pump holding pressure.
