finish the oil filter/system,pull the upper pan adaptor to drill and tap for the 480 drain,wire up the fans,finish the new coolant tank,and fab up a battery box for the drivers side.
i think im going to add another gate to the 480 just in case i need it. im pretty sure with the turbine housing options i have with the 362 and 480,that ill be in good shape bp wise. better be safe than sorry
thats about it. if i had about a couple days to myself,i could finish it.
with all the heavier 6.0-6.4 work ive been doing(headgaskets,blown engines,etc,etc). i can hardley keep up,so the little time i get that im not wrenching,i tend to chill a bit.
