Billet vs. Batmo
Craig@MFI
I ALSO RECENTLY RAN YOUR BILLET 75MM WHEEL VS BATMO WHEELAND SEEN A GAIN OF 90HP WITH THE BATMO WHEEL. JUST THOUGHT YOU MIGHT FINDTHAT INTERESTING.
Thank you,
Curt Haisley
Haisley Machine
8231 S. 200 W.
Fairmount, IN 46928
765 – 948 – 3164 PH
765 – 948 – 3163 FAX
www.haisleymachine.com
Craig@MFI
heres full graph
Craig@MFI
As far as cast making more power than a billet wheel i dont think that will ever happen
Even chase fleece picked up 100hp on 75 cast to 75 billet with bullseye standard billet wheel
jdgleason
Fort Collins, CO
Thank you,
Curt Haisley
Haisley Machine
8231 S. 200 W.
Fairmount, IN 46928
765 – 948 – 3164 PH
Thats a crazy huge gain. Do you have more specs on truck or charger? Any chance we could get dyno graphs of those?
It would be sweet if we could see the curves in relation to each other.
Craig@MFI
Danville performance
billet vs batmo
Craig@MFI
Another 6 blade vs 7 blade
Hats off to Fleece for being the first to give real live back to back dyno
data using our new 6 Bladed billet wheel vs the standard 7 bladed cast
wheel. After flow testing on our own in house turbo dyno test stand we
picked up 90 cfm at 30 psi but when fleece put it on the rollers using their
heavily modded Common Rail Cummins pick up it gained just over 100 whp. It
brought the power up from 864 to 968.
Craig@MFI
Thanks to Danville Performance for supplying us with some back to back dyno
data on their Duramax compound setup. After only changing the compressor
wheel from the standard 75mm cast to our new 6 bladed billet they picked up
60 hp and 110 Tq at 3000 rpm with a tremendous increase in spool up, towing
and drivability. Check out the dyno graph and look down around 2200 rpm and
you'll see a nearly 400 ft/lbs of torque increase
Craig@MFI
You would have to email curt haisley he just provided us with those numbers
08SUPERKING
EASY craig your going to over spool that batmowheel i phone...
haha just kinding..
Just so im clear they are comparing a 7 blade billet bullseye compared to the batmowheel right?
Craig@MFI
The one with the engine dyno was billet vs batmowheel
Sent from my BatmoCharged iPhone
jdgleason
Fort Collins, CO
Craig, what is your opinion on the wheels as far as reliability and strength? I've heard of some failures, but I'm not really sure what to think of them.
Craig@MFI
I've never seen one explode or has bullseye received a turbo back that the wheel was destroyed
The issues you seen with the dodge chargers was in the s300 frame the guys were spraying with no gate and breaking the shafts
And there was a rumor going around that another turbocharger guy started
