03_PSD
neat idea!
Instead of building a catch can, I simply bought a t-strainer.
These come in all sizes. I found one big enough to do the job. Plus they are cheap.
Local shop here in Denver had them.Hmmm not a bad idea. Where did you find it?
I had that same set up when I first did my CCV, but it still smelled. I dont care about the oil drip, but I want to get rid of the smell, meaning back to a stock location.
Did you pipe it back to your intake after that?
I have been wondering about having a catch can that is routed back to the oil fill cap...
How does that evacuate the crankcase vapors?
It wouldnt evacuate them, just keep intake turbo and intercooler clean
So I am still not sure what route to take... I liked the idea of plumbing into the exhaust but would be concerned about exhaust back pressure causing crank case pressure spikes... I like the idea of a strainer routed back into the intake - but have the same concern...
Sam
IM trolling in here but. what you guys use to plg the hole in the airbox>?
On the OBS I have used a heater hose cap.
Pocket, is there a place around here to look at one of those strainers?
Plus the oil that collects at the bottom of the canister shows me it's trapping most of the oil too.
Managed to mount it under the hood right behind the intake tube. The hose runs around and back under to the stock CCV inlet in the intake. Easy to see and it's right there to empty out when I change the oil.
How do the inside of the CAC tubes look with that?
I had my tubes apart a while back for something else and was really amazed how oily they were with the stock CCV.
