Tom S
- Joined
- May 20, 2011
- Messages
- 3,365
- Reaction score
- 1
Without a doubt put on new IPR O-rings if you have the IPR out.
DP-tuner and few other companies have a nice cover the gear bolt so you do not have to clean off silicon in the pain the butt spot again.
Will do... pm me your number just incase lol
Definitely need to remove lines from the pump. You don't have to remove them from the heads, but it's easier if you do to get them out of the way.Is there a list of all the stuff I need to buy anywhere?
Do I need to remove the hpo lines also?
Sorry for all the questions. I'm new to working on diesel trucks.
The pump is used. Has no new Gaskets or Orings being sent with it, that I know of...
I would do new IPR orings, and a new gasket for the pump just to be safe. You will have to remove the lines. If you are ordering parts online I can look up the part numbers for the above.
Make sure you get the correct HPOP gasket.
