Super08Duty
See if you can send me a pic of the exhaust housing casting numbers. Spools pretty late for a .9 housing. Ill try to take a video of how my charger brings up boost.
Throw a 62 on there. I bet a 80 feeding a 62 would be an animal on the street.
I agree with everyone else. Should have probably saw this problem coming. If it were me I'd put a 75 or compounds. Craig ran an s480 and saw zero gain over a 475
Why did you remove the dual fuelers?
Well ended up going a different route with the truck and something a little more mild. Went back to a single II pump, 60% nozzles, HD up pipes, a WOP wastegate, and a 73mm atmo. I'm thinking I'll upgrade the hp to a 59mm the probably leave the motor for a while. Truck runs pretty clean on gearhead tuning and the power is pretty impressive. I need to finish up some little odds and ends then it'll be 100% complete. I'm waiting on a fitting for the wastegate. Any tips on tuning them? From what I understand, datalog a few runs and dial in the gate to open at approx 85lbs EBP. Absoulte ebp?
No more single turbo.. :thumbdown:
oke:
Hoping to do some work stock pulls
In work stock yes. I didn't really have the need for dual pumps either only running 60s
