I also heard Brian only builds it one way. I guess I'm wrong in thinking he builds them different?
its been said already.... only, thing different is how the valve body is set to hold the power you ask... weather its 300hp or 1000hp... its all the same except how the valve body is set... its even the same valve body, just set different.
so you have had a BTS apart to see exactly what is in it or are you speaking from faith?
holy fugin **** man! they are the same.. only thing that would ever be different is if you had an older bts with different shafts... hell, if you ever bough a 10 yr old bts you could call brian and i would almost bet my dually that he would rebuild the 10 year old trans to current specs which only thing different is the shaft material.... i have been to his shop and seen him build a trans and the fugin crate the he pulls the shafts out of!!!! all the same!!!!!!
