My 2wd to 4wd Conversion Project
fordman2121
huntington, in
If the back of your trans looks like this you have the easy transmission to convert to 4wd. Unbolt driveline, remove a single bolt from yoke, remeove yoke and slide transfercase on. You will also need to change spring buckets.
So I looked at mine at its got the 2wd tail housing not the one pictured. Can I still just bolt a 4wd housing on and go then?
Dzlnut
Idaho
I'm not sure on that, we need a tranny guru to confirm the tail housing can be swapped.
TrailerHauler
Michigan
The 4r100/ E4OD needs a different output shaft and tail housing than the 2wd version in order to bolt up a transfer case. Not as easy as the 5r100.
yes-its six bolts i believe and the tail flange comes off with the output shaft. easy peasy.
stonepusher
San Antonio
When I did my conversion it when I had the 5r it had the 2wd tail housing. Still works the same just remove the tail housing, tail shaft and install new tail shaft, housing and t case
Need the 4wd mount as well
Dzlnut
Idaho
I did finally finish my project, it all works awesome and I'm very happy with the results. I did change my gearing from 3.54 to 3.73. My 04 6.0 had 3.73 and it towed awesome so that is why I changed.
jello
I know this is an old thread, but does anyone have the 2wd housing and output shaft they'de like to get rid of from their conversion? I'm going from 4x4 to 2wd on an '03.
Thanks
DZL JIM
North East Ohio
Thanks
You don't need a different housing, just the yoke that slides onto the splined output shaft. See the pic up a few posts, it shows this. I wouldn't mess with changing the housing if it was me.
Does anybody know if there is any wiring in the dash to plug-and-play an elect shift t-case? Them things are a dime a dozen, and manual shift cases are nearly extinct.
i have a harness here if you want to experiment-just pay shipping.
