Oil Cooler/Filter Relocate 6.4???
Taylor D
Sebring, Florida
Just bought the MPD Oil cooler delete plate. I have searched everywhere and can't find an answer to what everyone else used to piece together the rest of the setup. What filter, filter base, size lines/hoses and fittings and what cooler and where did you mount it?? Any help would be much appreciated. Pic's and exact where to get the items would be great.
Taylor
ncollins64
winchester springs, tn
I actually priced out a kit the other day from mpd. I was getting there plate and cooler with all the fittings and then get the RCD oil filter relocation kit.
White_monster
The great white north
I'm using a Mocal water to oil cooler, it's not cheap but the cooler can be cleaned easily. For the filter I'm using a pacbrake filter head for a 6.7 cummins. Lines are Parker pushlok hose in -10 size with AN fittings. Mine will all fit on the drivers side valve cover or in that area too. Pics when it's completed will be in my build thread.
ncollins64
That is correct, mpd didn't have a complete kit. I just priced there cooler and plate and got the RCD filter setup for the other side of things. I will have to do my own hoses after I mount everything in place.
White_monster
Should work. Only reason I wouldn't use an air to oil cooler is stop and go traffic and it's another cooler in front of the radiator. When your moving it'll work fine but I want some cooling in stopped situations. Also for the few of us in the cold temps a coolant to oil cooler like the factory cooler will help warm the oil to operating temps as well. Food for thought.
Taylor D
Sebring, Florida
Tried to look up the one you spoke of but wasn't sure which one. Do you have a link and whats the cost of the Mocal?
Taylor D
Sebring, Florida
Here's what I got so far will add more pictures as I complete it.
Sent from my SM-G900P using Tapatalk
06-sixoh
Bakersfield
I just started doing some research on this issue. Tired of doing flushes on the 6.0, and need to fix this correctly. After doing some quick adding up of parts and prices, it looks like the price is going to be the relatively close to the bulletproof kit, ranging from $1500-1700. This is just my rookie opinion. Good luck.
blk350on20s
If I did mine all over again I would do mpd plate. RCD filters head and filters(no line or fittings). Fluidyne oil to air cooler in the front bumper and run all my own -12 line. Would be a very nice setup.
blk350on20s
Oil to water cooler and filter head
Oil to air cooler
MPD plate
Keeps my oil at 182-185. It got to 194 on a 7 mile 7% grade in Colorado. Did awesome.
Halvy85
Bismarck, ND
What's everyone doing for oil lines on the turbos? I'm still running stock turbos for now till I see if the block stops leaking coolant. I was thinking -8AN off the plate and a -8 to -6 Y to feed both turbos.
blk350on20s
I ran -6 to both of mine. I used a T fitting right of the new oil plate. Its a -6 hole in the plate.
