1995 cclb restoration and build
swamp_ratt
hudson, wi
Pipe whiner was the one that got me wanting to do the swap to begin with, and was working with him to get an adapter plate made then I fell onto a 94 dodge truck for way to cheap to pass up so I settled for a 12v swap
I tried talkin to pipewhiner to get an adapter for a p7100, but he never responded so I searched and found someone else. I had a lot of questions for him for advice, but it didn't work out with him not responding, so I dug in! Not hard, just a lot of work
swamp_ratt
hudson, wi
Well, have my p7100 and sticks down at contagious diesel bein modded, muller performance is making my adapter and gear hub and hopefully gettin me some pushrods and valve springs. Found a guy in Missouri has an ag balancer for me for 75 plus the ride. Soon I'll call hart's diesel for my ss .093 lines, then it's on to driveshafts and a destroked stand alone for my Allison! Ahhh, I love progress! Still need to find a good hx50 so I can build my compounds!
Powerstroke Cowboy
Montana
Are you going to use the HX 50 as the high pressure turbo??? Or for the low pressure turbo???
I think you will have a nice running engine!!!
What HP numbers are you shooting for??
swamp_ratt
hudson, wi
The hx50 will be my primary with the ht4 as my atmosphere. My ht4 is around 85mm inducer. I'm shooting for anywhere from 800-1000 at the wheels, but my goal is also to keep it streetabla as a dd and tow rig!
Powerstroke Cowboy
Montana
Should work really good!!! A HX50 with a 16cm or smaller maybe even a 14cm housing with a gate should work really good!!!
And since you are feeding it with a 85mm turbo you should be good for about 800 or more RWHP with that air flow range..
Very nice!!!!
What all is bing done to the pump and Injectors??
swamp_ratt
hudson, wi
Very nice!!!!
Whatever Matt at contagious feels is necessary. I know it's stayin a 12mm with cut 181s and a 4k gsk. The sticks... If I had to guess, somewheres around a 6x16??
Powerstroke Cowboy
Montana
Sweet!! Glad to here it is moving forward for you!
I have been looking for a 99-07 Range Pickup, Lariat or King Ranch, cclb, 4X4, single wheel, F-350, manaul or auto.. With a blown engeine just so I could put a DT360 in it...
So I will be watching and asking questions to learn from the one who have done it!!
Thanks!!
swamp_ratt
hudson, wi
Jim dawg is doin a dt360 in his excursion on here, and pipewhiner on psn did it in a 99 f350 drw, but he's impossible to get ahold of
swamp_ratt
hudson, wi
Talkin to Matt via text right now... Pump is done, and he is cross referencing some nozzle info, but he has some that will work good. For my application and goals, he opted for 5x20 sacs! At the rate he's going I'll have em on my doorstep end of this week or early next week!
Powerstroke Cowboy
Montana
Sounds good... Will keep a watch on here to see what goes down..
Do you have a track close by you can test it at?? or a Dyno??
swamp_ratt
hudson, wi
No track or dyno close. When I get it all together I'm gonna tow it down to contagious and Matt and I are gonna put it on a dyno and dial it in!
Powerstroke Cowboy
Montana
Now that will be very good!!! Have the guys that built the injectors and pump dial it in for you.. that should get you the best results!!
swamp_ratt
hudson, wi
Yeah, I'm not cutting corners on this motor. Matt and I opted to go more extreme on my pump and injectors because of my long term plans of a ported head, billet rotating assembly and plans of 1500hp or so. We may go with brand new injectors as Matt is questioning the bodies of mine as of noon today. If that's the case I'll have 1500 into my pump and sticks alone. I sent him the check for the pump tonight as that's almost done so it'll be at my door in a few days. He knows that he has my permission to do what he feels will be the best route for my build. I see it as I better do it right the first time! I won't be able to afford another motor for a long time after all I'm sinking into this truck!
swamp_ratt
hudson, wi
Found an ag balancer for 87 bucks shipped outta missouri, hopefully between that and some water pump pulley work I can squeeze in a 6.0 fan. Pump adapter and gear will be here mid next week! Guess I better finish mounts and tear it back down so I can blast the frame and re paint it soon and do final assembly! Gonna have to order some 3.73 gears for the front end and a rebuild kit too. Next on the list of buys, driveshafts! Gettin closer slowly but shurely!
swamp_ratt
hudson, wi
Well, got my water pump pulley setup modded, removing the truck balancer tomorrow so I can get the ag balancer on. Pump came back last night. Just a little 480cc! Plenty for my wants... For now. Was supposed to have my adapters and springs and pushrods by now, but haven't heard back on em. Matt hopes my injectors should be done this week. If that's the case, she'll be gettin pretty close. Going to try out a manifold off a international 1066 tractor. It's similar in design to a 3rd gen cummins manifold but for the dt series engines. Now I just need lines, a lift pump and an hx50 and finish my piping and I should be able to start it.
swamp_ratt
hudson, wi
Here's a few more pics. Been working non stop lately so haven't had much time to work on this, but it'll come along
Truck balancer (blue) vs my new agricultural balancer...
The agricultural balancer mounts backwards so the larger ring will be toward the block unlike the truck balancer where the large part was away from the block. Should give me enough clearance to run a 6.0 fan and now I'll be able to change my belts haha
swamp_ratt
hudson, wi
Still need to gain more room at the water pump for the 6.0 fan! Have a few ideas that should give me enough without major revisions
swamp_ratt
hudson, wi
Definately making it known this is ih power, not cummins! The final paint scheme under the hood has been determined! All exhaust side components, injection lines, intake manifold, pulleys and accessories will be black! Intake side of turbos, intercooler piping, intake piping and brackets will be ih blue!
