6.4 RCLB DD/Tow Rig Build
CT9AIX
MA
Nice looking build bud. What are your plans for the oil filter/housing? I've been debating using the van relocation kit espically with MPD making it easy to adapt to AN fittings/hose now
Taylor D
Sebring, Florida
Thanks using a Fluidyne oil cooler with 12 an inlets and a Hamburger performance billet remote mount spin on filter mount that will be mount on the drivers side frame rail. It will use a wix xe filter little bigger than a 7.3 filter with a 5 micron rating
Sent from my LG-LS980 using Tapatalk
Marty
Elkton, MD
I see you got the MPD oil cooler setup like I suggested :D
Now where is the Marty's Diesel Fuel System Pictures :p
Taylor D
Sebring, Florida
Yep don't worry there will be pics of it. Just been super busy at work and only had a few hours here and there to work on it. The fuel system is next on my list though. Gotta get the bed pulled probably early next week.
CT9AIX
MA
I had never heard of hamburger performance before you mentioned it, but after checking out their stuff i'm pretty impressed. looks like real high quality... cant wait to see some pics of your install!
Taylor D
Sebring, Florida
Yeah i kind of stumbled across it when doing a search for filter heads. I bought everything for my setup from Summit Racing.
I will post some good pictures when done.
Taylor D
Sebring, Florida
Also installed the fox 2.0 shock and rear hellwig swaybar and also got my oil filter mounted inner frame rail drivers side mounted at slight angle to clear front driveshaft when removing it and for suspension travel.
Still have alot of parts to go on wanting on a few more goodies pulled the trigger on a 59mm 11 blade from Morgan and a few other changes
B585Ford
WV
How do you plan to set things up on Marty's sytem? Sump? Fuel Bowl Delete? Since this is a tow rig, I assume you are keeping your fuel cooler, right? Are you planning on ditching the regulated return?
Taylor D
Sebring, Florida
Thanks it's made by Hamburger performance bought it through Summit Racing it is 12 an in And out and I'm using a 5 micron wix xe 1970 filter
Taylor D
Sebring, Florida
Deleting the fuel cooler and vgt actuator cooler and the electric pump and cooler system that goes to it. Will watch fuel temps if they get out of check I'll add a in line cooler on the frame rail. NO Sump running a 3/4" feed (pickup tube) with hydro bulk head fitting installed in the oem sending unit lid and using the factory feed and return as my 2 returns. Also did the harpoon mod while I was in the tank.
B585Ford
WV
Thanks. :thumbup:
08SUPERKING
thanks for the info... set up looks nice...:fordoval:
