97 F-350 srw axle questions
DIE5EL
Northern Indiana
Had some teeth break off of my ring gear last night. After tearing everything apart the only thing I can salvage is the carrier its self. I been pricing the parts to rebuild ( ring and pinion, bearings, seals, also the limited slip friction disks ) Parts stores keep coming up with $1000+ or either total in parts or brand new carrier all put together.
The tag on my diff cover : 4L10 10 2 7L11
I understand that means that I have an 4:10's and it is a S10.25.
my question is, would it be cheaper to find a junk yard axle or craigslist axle or just rebuild my old one?. I have been finding them for anywhere from 150-400 dollars. Would it be worth my time and money to find a good used axle?. I just dont want to end up in the same boat im in right now..
Thanks guys for the input
Kyle
Redpower
Central Iowa
Depends on your situation. I don't drive my Diesel trucks much (5-9k / year) and my time isnt worth anything, so I would go for a used one. If you do a lot of driving or pulling maybe look toward the new parts.
DIE5EL
Northern Indiana
Thanks for the reply. I live in northern Indiana. I may have found a whole axle . Ill see what happens with it. Im gonna try my luck with a used one.
kadeninabnitt
Martinsville, IN
theres tons of them in indy between pic a part and pull a part salvage yards. i think a carrier with ring and pinion goes for around 40 bucks.
dave186
Idaho
I just sold one for $200, only had 80k on it, looked brand new inside. So you should be able to find a good used one for way less than the parts for a rebuild.
DIE5EL
Northern Indiana
I found one with 100,000 and it was a good price. Im crossing my fingers. Had to drive to Indy to pick it up last night. Hope its a good one..thanks guys
