Another 6.4 down.
Rmartin-97
Mcarthur ohio
Was driving tonight an it started missing and got a po281 code. I'm gonna check the copression this week and see if it's a cracked piston or bad injector.
7.3powerstroke00
Brownwood
Oughta be able to take oil cap off with it running and tell if getting compression in crank case from a cylinder... of course mine had a hole in the piston as well as being cracked in half but it was plenty obvious when pulled oil cap.
Rmartin-97
Mcarthur ohio
The blow by looked normal wen it broke.
7.3powerstroke00
Brownwood
I had number 3 go bad on mine and it looked good when I tore down. It never would throw a cel, it would start missing and could kill it and restart and run fine awhile, I drove it till it completely dropped that cylinder and threw a code.
