Beans Diesel Performance Sled Pull/Dyno Day Dec. 10!!!
BDP Sales
Murfreesboro, TN
Okay guys and girls, we're putting on the annual BDP Fire and Ice Sled Pull and Dyno Day. It is set for Saturday December 10th. Gates open at 8:00 a.m. Dyno starts at 8:30 and will go until there are no more trucks to dyno.
For the sled pullers: Driver's meeting is at 12:30 p.m. Pulling starts at 1:00 p.m. 100% payback for all classes.
Admission will be $10 per person at the gates. If you are pulling or getting on the dyno, you will have to pay the $10 at the gate, but that will be deducted from your hook fee/dyno fee.
Hook fee is $40
$85 for 3 dyno runs
For those that are wanting to stay the night, i will post some links to the closest hotels, which are about 20 minutes away. If you are coming with a trailer, you are more than welcome to drop it here the night before. Anymore questions, just post in this thread and I will answer them.
Hope to see everybody on the 10th!!
CLASS RULES
Work stock
Rules:
Work Stock Class Regulations
The Work Stock (WS) class is designed for daily-driven, on the road pickup trucks (full-bodied diesel pickup trucks). Valid DOT registration and license plates are mandatory. The vehicle may be two or four-wheel drive.
Designation: WS followed by competition number
Weight breaks: 8200 lbs. Weight is with driver
REGULATIONS:
Ballast: Ballast is permitted. Hanging front weights are prohibited. Ballast may be added in the bed of the truck. If used, ballast must be securely fastened to the bed. Final decisions rest with the technical department.
Batteries: The batteries must be securely mounted. They may not be located in the driver compartment or forward of the radiator core support.
Body: The body must be the OEM truck body, including the full bed floor. The body must retain full sheet metal. Metal after-market hoods are permitted. Fiberglass is prohibited. The hood must be closed and securely latched while the vehicle is hooked to the sled. The complete OEM firewall and OEM floor pan is mandatory.
Brakes: Four-wheel hydraulic brakes are mandatory.
Chassis: The OEM chassis is mandatory. The engine must be in the OEM location for the body used. The vehicle must retain the full OEM chassis. Wheel tubs, back-half conversions, tube chassis, etc., are prohibited.
Cooling System: Radiators must be in the stock location and be of at least stock size.
Credentials: All drivers must have a valid state drivers license.
Driveline: An OEM transmission and transfer case are mandatory. They must have been an option on a one-ton or smaller pickup.
Driver Restraint System: The OEM restraint system is mandatory and must be worn.
Engine: The engine is limited to a stock-appearing, OEM make-specific compression ignition engine. NITROUS OXIDE is prohibited along with other oxygen extenders as well as the use of PROPANE is also prohibited. All system components MUST be removed from the truck.
Exhaust: The exhaust must exit rearward of the driver’s compartment. Stacks exiting through the hood or fender well are prohibited. If the muffler or catalytic converter have been changed from stock, two 3/8 inch diameter bolts must be installed through the exhaust pipe in a cross pattern within one inch of each other as close to the turbo as is practical.
Fire Extinguisher System: A fire extinguisher system is permitted. It must be securely mounted.
Fuel: The fuel must be pump #1/#2 diesel only. Soy/Bio-diesel fuel is permitted. Off-road diesel fuel is prohibited.
Fuel Injection Pump: The fuel injection pump is limited to a stock-appearing, OEM engine model-specific pump only. The use of multiple high-pressure common-rail fuel pumps is prohibited. Powerstroke engines with a single factory turbo may utilize a second HPOP. Pumps from different years in the same engine model may be interchanged.
Fuel System: The OEM fuel tank is mandatory and must be used. Racing fuel cells are prohibited and must be removed from the vehicle.
Harmonic Balancer: All engines turning 4500 RPM and higher must be equipped with a harmonic balancer or damper meeting SFI Spec 18.1.
Hitch: The hitch must be a receiver-style hitch; reinforcements are permitted. Reinforcements must not extend forward of the centerline of the rear axle. Trick hitches are prohibited. The hooking point must be the rear-most point on the vehicle and must be rearward of the stock location of the tailgate. The hitch must be horizontal to the ground and stationary in all directions. Bumpers may be notched or removed. The hitch’s height from the ground may not exceed 26 inches on 4wd units and 30 inches on 2wd units. The hooking point must have a minimum 3.750-inch inside diameter opening for the sled hook. The hooking point will be measured to the center of the clevis loop.
Interior: A complete interior, including dashboard, door panels, headliner, etc., is mandatory. Two matching front seats are mandatory. Aftermarket seats are permitted; they must be fully upholstered. All factory controls (lights, signals, horn, windows, wipers, etc.) must be retained and be operative. The use of hand-throttle controls are prohibited.
Rear End: Non-OEM rear-end housings are prohibited. It must have been an option on a one-ton or smaller pick up. Rear axle bolts must be covered by a cap or shield.
Steering: The vehicle must retain the full, original OEM steering gear. The vehicle must retain the original OEM power steering assistance, if it was so equipped. Additional stabilizers are permitted. Non-OEM power assist methods are prohibited.
Street Equipment: Complete headlight and taillight assemblies (all) are mandatory and must be operative. Complete OEM windshield and windows are mandatory. Windows must be operative per factory specifications; that is, they must open and close via OEM electrical or mechanical means.
Suspension, Front: The upper mounting point for strut assemblies must be in the factory location. Adjustable caster/camber pillow ball mounts are permitted. The lower control arm may be strengthened provided factory-mounting points to chassis are maintained. The lower mounting point for the strut assembly may be modified for improved caster or camber. Strut tower braces, lower tie bars, sway bars, and limit straps are permitted. Traction bars and devices are permitted. Final decisions rest with the technical department.
Suspension, Rear: An OEM-style suspension is mandatory. Lowering or raising the vehicle height with suspension modifications is permitted. Traction bars and devices are permitted; they must be bolt-on only; welds are permitted for attachment to frame or axle
housing. All OEM suspension mounting points must be retained and used. Sway bars, limit straps, and camber kits are permitted. The rear suspension must maintain a minimum compression shock travel of one inch; compression stops must be adjustable. All rear suspensions must use at least one working shock absorber per wheel. Airbag spring assistance is permitted; airbag compressors must be disconnected.
Tires: The tires must be DOT street tires. Cut tires are prohibited.
Tow Vehicles: Tow vehicles are prohibited.
Transfer Case: Non-OEM transfer cases are prohibited. The transfer case must have been an option on a one-ton or smaller pick up truck.
Transmission, Automatic: Non-OEM transmissions are prohibited. Aftermarket torque converters, valve bodies and internal components are permitted. Transmission brakes are prohibited. Any non-OEM floor-mounted automatic transmission shifter must be equipped with a spring-loaded positive reverse lockout device to prevent the shifter from accidentally being put into reverse gear. A functional neutral safety switch is mandatory. All transmission lines must be metallic or high-pressure-type hose. All vehicles with engines running 4500 RPM or more and using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and must be labeled accordingly. A blanket-type shield is permitted; it must be appropriately labeled as meeting SFI Spec 4.1 and it must extend from the rear of the block to the front of tail housing with a minimum six inch overlap where it is fastened. All non-blanket-type shields must incorporate two (or one, per manufacturers instructions) 3/4 inch by 1/8 inch straps that bolt to the shield on each side and pass under the transmission pan unless the transmission pan is labeled as meeting SFI Spec 4.1. All vehicles with engines running 4500 RPM or more and using an automatic transmission must be equipped with a flex plate meeting SFI Spec 29.1 and be covered by a flex plate shield meeting SFI Spec 30.1.
Transmission, Manual: Non-OEM transmissions are prohibited. Aftermarket internal components are permitted. A clutch meeting minimum SFI Spec 1.1 or 1.2 is mandatory on all vehicles with engines running 4500 RPM or more. All manual transmissions must be clutch assisted. Sequential shifters are prohibited. All vehicles with engines running 4500 RPM or more and equipped with a manual transmission must have a flywheel shield labeled as meeting minimum SFI Spec 6.3 or greater. Applications for which an SFI Spec flywheel shield is not available may use a properly attached SFI 4.1 or 4.2 blanket that completely covers the bell housing; it must be attached to the block and extend rearward to the transmission with a minimum six inch overlap where it is fastened.
Turbocharger: The turbocharger is limited to a stock-appearing, OEM/Factory make-specific charger only. Turbochargers from different years in the same make may be interchanged. 6.4 liter Powerstroke engines may utilize the factory twin-turbo configuration.
Water Injection: Water injection is prohibited. All system components must be removed from the truck.
2.6 Rules:
The 2.6 class is designed (full-bodied diesel pickup trucks).
Designations: 2.6 followed by competition number
Weight breaks: 2.6: 8000 lbs. Weight is with driver Minimum weight of 7500lbs
REGULATIONS:
Ballast: Ballast is permitted. Front hanging weights are allowed, no t to exceed 60 inches forward of the center of the front axle. This will be measured from center of front wheels to end of weight assembly. Ballast may be added in the bed of the truck. If used, ballast must be securely fastened to the bed. Final decisions rest with the technical department.
Body: The body must be the OEM truck body, including the full bed floor. The body must retain full sheet metal, after-market hoods are permitted. The hood must be closed and securely latched while the vehicle is hooked to the sled.
Credentials: All drivers must have a valid state driver’s license.
Driveshaft Loops: All trucks must have at least six inch wide u-joint shields around the rear u-joint constructed of at least 1/4 inch steel or 3/8 inch aluminum that will safely contain the u-joint and the end of the rear shaft. All shields must be securely mounted to the vehicle. Any front shaft u-joint that is visible from the side of the truck must be shielded to contain the u-joint and the end of the shaft.
Engine: The engine is limited to a stock-appearing, Engine and transmissions can be interchanged between Dodge, Ford and GM as long as they came in a 1 ton truck or less from the factory. Complete engine must have stock appearance except where otherwise noted in these rules. Aftermarket intake manifolds are allowed.
Exhaust: All vehicles must be equipped to direct exhaust upward. Two 3/8 inch diameter bolts must be placed through the exhaust pipe in a cross pattern within one inch of each other, within 12” of the turbo.
Firewall: The complete OEM firewall is mandatory.
Floor: The complete OEM floor pan is mandatory.
Fuel: The fuel must be pump #1/#2 diesel, Soy/Biodiesel fuel.
Fuel Injection Pump: The fuel injection pump is limited to a stock-appearing, OEM engine model-specific pump only. The use of multiple high-pressure common-rail fuel pumps is legal. Powerstroke engines with a single factory turbo may utilize a second HPOP. Pumps from different years in the same engine model may be interchanged. P7100 pumps are allowed to run RSV (ag governors)
Fuel System: Racing fuel cells are permitted
Hitch: The hitch must be a "Reese"-style hitch; reinforcements are permitted. Trick hitches are prohibited. The hooking point must be the rear-most point on the vehicle and must be rearward of the stock location of the tailgate. The hitch must be horizontal to the ground and stationary in all directions. Bumpers may be notched or removed. The hitch's height from the ground may not exceed 26
inches. The hooking point must have a minimum 3.00 inch wide x 3 ¾ length inside diameter opening for the sled hook. The hooking point must be a minimum of 44” from the center of the rear axle to the center of the hooking point. The hooking point will be measured to the center of the clevis loop.
Nitrous Oxide: Nitrous oxide is prohibited. No other oxygen extenders are allowed. All system components must be removed from the truck.
Propane: Propane is prohibited. All system components must be removed from the truck.
Steering: The vehicle must retain the full, original OEM steering gear. The vehicle must retain the original OEM power assistance, if it was so equipped. Additional stabilizers are permitted. Non-OEM power assist methods are prohibited.
Suspension, Rear: An OEM-style suspension is mandatory. Lowering or raising the vehicle height with suspension modifications is permitted. Traction bars and devices are permitted; they must be bolt-on only; welds are permitted for attachment to frame or axle housing. All OEM suspension mounting points must be retained and used. Sway bars, limit straps, and camber kits are permitted. All rear suspensions must use at least one working shock absorber per wheel. Airbag spring assistance is permitted; airbag compressors must be disconnected. Blocked suspension is permitted.
Transmission, Automatic: Non-OEM transmissions are prohibited. Aftermarket torque converters, valve bodies and internal components are permitted. Transmission brakes are prohibited. Any non-OEM floor-mounted automatic transmission shifter must be equipped with a spring-loaded positive reverse lockout device to prevent the shifter from accidentally being put into reverse gear. A functional neutral safety switch is mandatory. All transmission lines must be metallic or high-pressure-type hose. All vehicles using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and must be labeled accordingly. A blanket-type shield is permitted; it must be appropriately labeled as meeting SFI Spec 4.1 and it must extend from the rear of the block to the front of transmission main body the bell housing area is to be completely covered six inch overlap where it is fastened. All non-blanket-type shields must incorporate two (or one, per manufacturer’s instructions) 3/4 inch by 1/8 inch straps that bolt to the shield on each side and pass under the transmission pan unless the transmission pan is labeled as meeting SFI Spec 4.1. All vehicles using an automatic transmission must be equipped with a flex plate meeting SFI Spec 29.1 and be covered by a flex plate shield meeting SFI Spec 30.1.
Transmission, Manual: Non-OEM transmissions are prohibited. Aftermarket internal components are permitted. A clutch meeting minimum SFI Spec 1.1 or 1.2 is mandatory on all vehicles. All manual transmissions must be clutch assisted. Sequential shifters are prohibited. All vehicles equipped with a manual transmission must have a flywheel shield labeled as meeting minimum SFI Spec 6.3 or greater. Applications for which an SFI Spec flywheel shield is not available may use a properly attached SFI 4.1 or 4.2 blanket that completely covers the bellhousing; it must be attached to the block and extend rearward to the transmission with a minimum six inch overlap where it is fastened.
Turbocharger: The vehicle is limited to a 2.6 inducers bore single turbocharger. The compressor wheel must protrude into a 2.6” bore for 1/8”. The inlet will be measured using a 2.65 inch plug the plug must not be able to enter the inducers bore. A stock map width enhancement (MWE) groove is allowed. No MWE groove will be allowed that has a width greater than .200”. All provisions allowing air into the wheel other than via the bore and the MWE groove are prohibited. The vehicle driver will be responsible for making compressor wheel accessible for tech personal to measure bore and be able to inspect compressor wheel.
Ice Water Intercoolers: Are permitted
Wheelbase: The vehicle must retain the original factory wheelbase and track width.
3.0 Rules:
Trucks must remain stock appearing. Must have full size steel or OEM type body. The bed of the truck must have a metal floor, if bed is gutted 200 lbs of movable weight must be placed rearward of the centerline of the rear axle,
Designations: 3.0 followed by competition number
Weight breaks: 8000 lbs. Weight is with driver Minimum weight of 7500lbs
REGULATIONS:
01. Maximum engine size will be 460 cubic inch. Engines must come from factory in one ton or smaller diesel pickup truck. Engine must remain in stock location as intended by manufacturer.
02. Front of engine block can be no farther forward than 17” of centerline of front axle.
03. Hook point must be no closer than 44” of centerline of rear axle, hitch height maximum of 26”, with a minimum of a 3.5” X 3.0” opening. Hitch point must be easily accessed. No “trick” type hitches permitted. Hitch must be stationary in all directions. Hitch must be frame mounted. Hitch must be mounted center line of rear axle or behind. Hitch must not exceed a maximum of 25 degree angle from pivot point to hook point.
04. One turbo with one pressure stage permitted. Maximum of 3.0” Opening on intake wheel. Map width enhancement is allowed not to exceed .250. Compressor wheel must protrude into three inch bore 1/8”, intake housing may not exceed three inches turbo mounting plates are permitted.
05. Exhaust must exit straight up, with (2) 3/8” bolts mounted in a cross pattern no more that 1” apart as close to the turbine wheel as possible, no more that 6” from turbine wheel
06. No cast iron clutches or flywheels permitted.
07. Fuel safety kill and/or air shutoff must be installed on the rear of truck. Kill switch will be securely mounted to the back of the vehicle and have a two (2) inch diameter ring to attach the sled.
08. No fuel lines or tanks permitted inside of truck cab unless securely mounted in marine box
09. Computer chips and boxes permitted.
10. Fuel Systems: Largest fuel injection pump allowed will be a P-Pump with only one plunger per cylinder. (No Sigma pumps).
11. Must be D.O.T. approved tire. Maximum tire height 35” no studded tires or chains. No alteration to tires allowed. No bar or terra tires. Dual rear wheels are permitted.
12. Water injection permitted
13. Front weights must be no more than 60” from the center line of the front axle to forward most point and be securely fastened. No weights are allowed in cab of truck if in bed of truck they are to be securely fastened to bed of truck.
14. Fuel limited to diesel fuel and bio-diesel only. No alcohol, nitrous, propane or any oxygen enhancing agents allowed.
15. Drive train will consist of the following: Any front axle, any transfer case any rear axle. No planetaries permitted.
16. Axle shields are required. Shield to be .060” thickness steel or aluminum. Shield not to be mounted to axles ends or hub bolts. A hole may be cut in one to allow locking in of hubs.
17. S.F.I. Bell housing Blankets and /or S.F.I Blow proof Bell housing required.
18. All U-joints must be shielded 360 degrees with 3/8” thick aluminum or 5/16” thick steel. Shield will be 6 inches long minimum and centered on U-joint. Inside diameter of shield will be no more than 2 inches larger than U-joint.
19. All intermediate shafts between the transmission and transfer case will be totally enclosed in 3/8” aluminum or 5/16” steel, ¼” of shaft may be visible.
20. Suspension modifications are permitted. Removable suspension blocks are permitted.
21. Fire Extinguishers, helmets Snell 85 or better, SFI fire suits, shoes and seatbelts required
Bean
So the pull is back on now, was not planning on having it but I have given into pier pressure so now its on.
Stay tuned for prizes and other news.
TURTLE
OHIO
I think Im going. You said we could camp even though there are no hook ups right?
woodduck97
Maryland
Another year I will miss because I am going to Arkansas that weekend. Don't y'all have a spring pull?
Hotrodtractor
Mingo, Ohio
Ummm sled pull is on? Damn..... I have a phone call to make and some suspension to fix!
This is really going to kill the schedule for the dmax's new suspension.... damn it.
DIESEL SHOP LLC.
GRISWOLD, CT
Wish i could make it, would really like to put the 7.3 to the test. Anyone who has the chance should go its a great event with great pple!!!!!
Jhaddox
Negley, OH
Gonna try to make it, im goin to the PRI convention the week before this so we'll see if i have enough extra cash to hop on a plane and make it down
whats the closest airport to you guys?
