CCLB project
BigRed97
Saugus MA
back in may i picked up a CCLB 2wd with a worn out V10 for short money!($1,500)
the plan is to swap almost everything out of my 99 into this one
it needed a bed, scored a brand new one for $300
planning on going with 05+ axles/suspension
started cleaning up the rear frame while the bed is off
got it all cleaned up and coated with SEM rust seal (simillar to POR15)
recently got a little accomplished....slower than originally planned...
cab is gutted, getting a little body work done, and ready for sound insulation, and painting all the jams and engine bay....
06 rear axle is under with stock springs for now (08s to be swapped later)
thats it for now, hope to have some significant work done by next weekend..
BigRed97
Saugus MA
progress....engine bay cleaned and painted, sound insulation started(boy is that tedious work!)
Txpsd
This is coming along nicely, I love seeing these complete restos like this.
BigRed97
Saugus MA
yes it will be 4wd with 05+axles/suspension...
as for the gas tank it self, can I just put the diesel pick up assy into it with out issues)(after i empty it of course)
co04cobra
WV
Nice project. Seems like ones like this always end up taking longer then expected. Main thing of course is to get everything you want done in it before it goes back together. I hate tearing **** apart twice:doh:. On the tank the gas fuel pump mounts to the bottom of the tank in a plastic circle made into the tank. You can modify it to work by cutting that out of the bottom, but if there is nothing wrong with the your other tank I would just use it. Hope it helps.
BigRed97
Saugus MA
my other tank is the smaller one, i'd like the larger capacity....i'll take a look inside to see what i can do
TrailerHauler
Michigan
Great project! I love seeing these trucks completely gone through from top to bottom, cleaned up and modified!
Vader's Fury
Chesapeake City, MD
Nice project! I am working on a similar project with my 350. Got it all stripped down, but started on the 450 so it has been sitting just waiting.
What kind if sound deadening did you use?
Also any more info on the paint you used for the frame? I am hoping to get mine sand blasted in next couple of weeks.
BigRed97
Saugus MA
sound deadening is a combo -
-RaamMat, PhatMat that some buddies had left over was used on the firewall, front floors, roof, and large square inside the doors.
-A sheet of some dual layer foam/dense rubber mat was added to the firewall over the butyl materials.
- then for the rear floors and back of cab I cheaped out and got a roll of the peel and stick roofing stuff from HD. (its surprisingly close to the PhatMat in consistancy and weight)
I still plan on covering everything over in a dense closed cell matting.
I can get more info on the rust coating next time im at my shop. but its made by SEM
BigRed97
Saugus MA
progress...
finished vibration absorbing layer of insulation..
then covered in a dense "gymnastic rubber" closed cell foam...
BigRed97
Saugus MA
more progress..
got the carpet, rear pannel cover, and a most of the plastic on the RH side installed
and got the dash out of my e99 and installed in the CC
BigRed97
Saugus MA
thanks!
got a little more done today...
fender wells, battery trays, and engine bay wiring all installed..
and spent some time (that should have been spent on something more important)cutting up the headliner to install the 08 over head console. (still needs a little trimming to clear the sun visors, and then dye to match)
