gauges
dommel01
ok guys i ordered a set of glowshift gauges, boost trans temp an egt, where is gonna be the easiest place to put the egt probe? how should i hook up the trans temp? for the boost should i drill the intake manifold, or could i just drill the intake elbow? sorry for the stupid questions, just wanna get an idea of what i gotta do
MrMike2010
Long Island, NY
The egt probe will have to go in the exhaust manifold. On my 6.0 I drilled into the driver side mani from the bottom with the motor running in hopes of pushing all the shavings out as I drilled.
The boost fitting will have to be tapped into the intake elbow. Some aftermarket elbows will have pre-tapped ports which is another option if you have a deleted egr.
The drivers side trans case has a test port that you can remove the small bolt and screw the temp sensor right in. That should be it.
pog
psa
you ordered the glowshift max tow? i like the way those look.
i searched glowshift and it seems a lot of people had premature failures. i have only had autometer so i cant speak from exp.
6
6.4stroke
Guest
yea im going to pick up a set of gauges soon from dieselmanor for my 6.4 i think they have best instructions also and to the OP I just heard a lot of people having problems with glowshift maybe youll get a good set just heard a lot of problems with them
