semperfidooordie
Thats what I thought just wasn't certain...now I know what is next on my list. Thanks!
Dont make me make instructions oke:Huh?
Just cause you can set the high low settings doesn't mean it reads that high bud. The factory map sensor is pinned at 36-37psi.
Well this was actually easier to fix than I thought it would be. With the help of dustin we put a map sensor in place of the air filter minder and used dustin's boost harness for the dashdaq to read it. Its a pretty cold day here this morning so atmospheric pressure was 12.1 psi. With Erics current air filter it pulled down to 10.9 psi a 1.2 psi drop. An acceptable drop according to donaldson is .3 psi. I procured a new AFE air filter that is quite a bit larger than erics current filter. When I tested the new filter atmosphere was 11.9 and under a full run it pulls down to 11.6 right in line with the .3 acceptance. The filter minder no longer pulls down at all either. Just for comparison I also did a full run with no filter. Atmosphere waste 11.9 and with no filter it pulled to 11.6 as well. So i'm pretty confident this filter will work fine as long as it is kept clean.
I also for comparison since it was here went out and tried this on Mal's Max Power turbo truck. He has a Banks air box with no lid on it. Atmoshere was 11.9 and his pulled down to 11.2 a .7 drop. His truck however does not pull the filter minder in. But it looks like his truck will be getting a new intake system as well.
Ok, Might have figured out why some trucks do pull the minder in when some don't with the same set up. The minder on my truck is part number 7C34-9N622-DC. I found a TSB saying that trucks built before 9-13-09 having issues with the check filter light coming on should have the filter minder replaced with part number 8C3Z-9N622-A. So I would assume trucks built after 9-13-09 came with part number 8C3Z-9N622-A.
I don't have anything to check how much vacuum it takes to suck the minder in, or I would have checked it already. I'm curious to know.
That might be true, but it doesn't apply to this. Mine dropped 1.2psi with the smaller filter on it. That much drop is too much and if an updated sensor wouldn't be sucked in with that, well isn't good either. Since we are speculating that amt of drop can and is detrimental to a turbos life span.
So why didn't it pull the minder in? Do you think the 76mm would pull the banks in?
Also, why is that dyno not inside yet? It winter man!
