It's official
Oregon
Saturday was driving out to my dads shop to change oil and install a new thermostat.....untill pow and a bunch of white smoke. Here is the after math. Yes not one but both head gaskets are destroyed! All happened at 55psi
In this one you can see where I no longer have a freeze plug as well. Haha!
Looking above cylinder #1 where my push rod should go.
Driver side
Passenger side
Oregon
Got gaskets, springs are one the way. Getting some quotes on ARP's, heads are going into machine shop this weekend. Block is going in to just to be checked over to be on the safe side and over looked.
davey99ps
Waterford WI
I've got my studs, springs, pushrods, an new gaskets sitting on the shelf waiting on me to find the time to put it all together. In the meantime, I keep waiting for this to happen everytime I really get on it. Good luck with getting it back together, hope its not to bad
tmillburg
hey, i dont know if anyone tokd you or maybe you already know buttttt your gaskets are junk
Translated from Morse Code
Derek@Vision Diesel
Canby, OR
haha
These never get old.... wanna see an even better one?
Yes we are going 45mph and no the truck we are riding in is not running, and yes the gaskets failed about 15 minutes before this :)
flippincgfighter
Oregon
That dodge is lifted too high.....haha
Wow you really blew it. Way to go Kurtis!
Tell Derek to keep his fingers off the pistons before you take pictures.
Hotrodtractor
Mingo, Ohio
Let me get this straight..... you were going to install a new thermostat - so you knew something was wrong with your current thermostat..... and you still thought that 55psi while just driving out the the shop was a good idea on a truck with a bad thermostat AND no head studs?
Amazing.
Oregon
Amazing.
Live and learn
TurboM700
Minnesota
Amazing.
Was thinking the same thing. Some times your cant fix stupid.
Derek@Vision Diesel
Canby, OR
It has nothing to do with being stupid, he was fully aware that the possibility of blowing a head gasket. When the time came he would pull it and stud it, fix oil leaks, and deal with some exhaust leak issues.
I believe calling it stupid is a little harsh....
Dieselboy.
Surrey B.C.
No, Im with HRT.
55psi and no studs ?
What mods do you have to hit 55psi ? I thought that was a typo for 5psi.
If you cranking that much boost in her with no studs what did you expect.
smokedout250
harrisburg oregon
He knew it was gonna happen! It was his choice! You may think its stupid but it all comes down to what he thinks and what he chooses to do. He is taking the proper steps to fix the issues now!
Derek@Vision Diesel
Canby, OR
No, Im with HRT.
I think he meant 45psi... Its a stock turbo still.
Just pushing the limits of things and then upgrading them. If he was afraid to break something he would of studded it in the truck. Instead we pulled the motor and are doing springs/studs/up-pipes/fixing oil leaks.
In no way was anyone surprised or upset that it happened, it was actually fun :pint:
