Strokin_4_Life
is anyone running elites drop in Jr Highpower Atmosphere Turbo with the stock vgt? how decent would this set up be on stock fuel? what kind of boost is seen? also how would the power compare to elites 72mm atmo turbo?
This is a good question. I'd like to hear what people know/think about the 76 being used with a stock vgt. It would be a nice upgrade to have and then later get to the vgt. Would you be fighting the vgt too much to gain power?
Your going to give up a little hp my guess is about 50 maybe more. Is the vgt worth upgrading. .. probably but bang for the buck you are cheaper just doing the 76
I wanna say jd has a stock vgt but I might be wrong
Sent from my SCH-I545 using Tapatalk 2
Wow. That much. I'm at 730 now with the 71 with plenty of fuel left. I want 800 fuel. Is that feesible with just an atmo upgrade? I really need the vgt but its so hard to spend that amount of money and not gain anything until the bigger atmo goes on.
Would you guys mind telling me who jd is? Im pretty much at sea level where im from.
He's a pretty boy in Colorado
right on thanks!screen name jdgleason on here
Last I talked to jd he was loving the atmo, but he does have fuelers. Probably aiding in spool up. I'm wanting to run this on stock fuel, but need to do 700 on fuel so the vgt might be necessary
Sounds like a sweet drop in for sure!
Any sound clips?
